Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
How difficult is it to replace wifi ic?
Picked up an iPhone 6 on the cheap ($60) with greyed out wifi. Because there's not a massive risk in the price, do you think it'd be possible to replace the Wifi IC successfully or is it a difficult task that I should let a specialist do?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I guess if you have to ask the question, then yes, it is too difficult for you to do :>).
This is by no means an easy repair unless you have the proper tools and some experience working at this scale. It certainly shouldn't be the first thing you try. There are plenty of videos on youtube that make it look easy but these folks are generally using multi-thousand dollar micro-soldering workstations under stereoscopic magnification.
Do you have a hot air station (not a heat gun)? Are you experienced in removing micro-BGA IC's from densely packed iDevice logic boards?
If you don't feel comfortable doing this yourself, then look for a repair shop that does micro-soldering repairs. It shouldn't be a very expensive repair.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
@refectio thanks! I'm pretty new to repairs and completed nothing close to a wifi IC, I guess I'll stay away from it then haha
door
Voeg je antwoord toe
Matt Howard zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 1,405
