Ga door naar hoofdinhoud
Reparatie- en apparaathandleidingen voor de 2016 Samsung Galaxy J5 smartphone, model SM-J510FN.
back button & apps button KEYS not working
Apps button & Back Button not working, tried that Firmware version (*#2663#) thing also, TSP FW update and Touch key FW update both, still not working. Please help its == Samsung J5 ==
Is dit een goede vraag?
Score 10
3 opmerkingen
Just replaced lcd on a friend's note 5 and back/recent keys will light up but no action.. have tried (*#2663#) ,hard/soft reset with recovery reboot and deletion of partition cashe', With no avail. Is it possible the ribbon cable connection for the lcd isn't a complete one? Allowing the picture but not the soft key functionality?
door
It should be noted that the light for the back button and recent apps button might also be turned off if your samsung is in Power Saving mode. Go to Settings>Power Saving>Restrict Performance and uncheck the box that turns these lights off. Once the box is unchecked, your phone will use a little more battery power in the Power Saving mode, but your Back button light and your Recent apps light will both illuminate.
door
If you want a permanent fix order the touch capacitive buttons + home button + headphone jack online and install it
door
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Gekozen oplossing
Hi!
This is what I've got for you.
Go to Settings > Accessibility > Dexterity and interaction > Assistant menu
From here, toggle the switch to "ON". This will create a hovering circle with a window with four panes inside it. If you interact with the hovering circle it will open a new window in which you have access to the back and recent apps buttons via an onscreen button.
Not sure what has disabled the hardware buttons, but this should give you access via onscreen software.
I know it's not a true fix, but a work around.
Was dit antwoord nuttig?
Score 21
16 opmerkingen:
Omg it works!!! Thanks you so much
door
It Worked. You Made My Day. Thanks.
door
What do I do with the last windows
door
Great ... good solution
door
Thank you Alex!!! God bless you!I have trouble this for 4days
door
11 commentaren meer tonen
If it is similar to the j3, the screen is above two sensors that look like small circuit boards. I replaced a screen a while back, and ran into the same issue. I took the screen back off and re installed it. I made sure to line the groves on the bottom of the screen with the small touch sensors. It fixed the problem for me. When installing a screen you should always test it first. You can plug the screen in, turn the phone on, and dial *#0*# this will bring up several test options. The touch test will allow you to test the digitiser, and the subject test will let you test all the buttons including the back and apps button
Score 3
2 opmerkingen:
Sub key test* not subject. Sorry for the typo
door
Back button app. is the last solution, but is working.
door
I have a j5 prime with the exact same issue, I found app in app store called easy home for samsung. It works perfectly, hope this helps
Turning off "Power Saving" fixes the issue of backbutton not working. This is an annoying bug.
Voeg je antwoord toe
Lionel Myers zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 106,361
