Ga door naar hoofdinhoud
Huawei's 2017 flagship smartphone. Released in March 2017. Features a unibody case and dual rear-camera setup developed in partnership with Leica. Comes in 32/64 GB storage options and six different finishes. Model numbers VTR-L09, VTR-L29, VTR-AL00, VTR-TL00.
48 Vragen Bekijk alle
Is a bent huawei p10 fixable?
Huawei p10, bent from the top left corner. The front glass is broken and sim slot doesn't work but rest everything works. Is it fixable? If it is, is it a feasible solution or its better to buy a new p10?
Is dit een goede vraag?
3 opmerkingen
how do you bend a phone?
door
That's literally what I asked when he posted his question, but I deleted it because I was affraid that @mayer might get upset :))
door
@alexniculescu You provide excellent answers. I may make a suggestion to you once in a while as to how to improve it but I try to make it as constructive criticism . If you look at your activity page and votes, you will see that 41% of all your up votes are from me.
@theelitepro_gd You were not making good answers at all nor were you even thinking, so I jumped on you hard because you did it so many times.
The most common way to bend a phone is to put it in your back pocket and sit on it. However, I've also seen it happen when a horse stepped on it while in the back pocket.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
depends on your technicians.
you could replace the Housing, sim tray and screen.
These parts would cost around 250$ CAD To purchase, assuming you can find them at the same source.
A lot of labor is involved, and you're likely looking at arounf 450$CAD or more for a repair from a shop.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Eftakhar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,441
