Won't start when turned on
It won't power on it started by being intermittent about powering on and now it won't power on.. there is no display when I try to power on. The LED on the power switch lights up but that's all that happens. It has a solid state drive
Is dit een goede vraag?
5 opmerkingen
Hi!
Could you tell us what happens if you remove the hard drive/ SSD completely and power it without it?
door Alex Niculescu
Does the laptop have a VGA or HDMI plug? If it does plug one and then turn it on and see if you can view your laptop with your tv or monitor, have you tried putting a flashlight to the laptop screen to see if the backlight hasn't gave out.
door Mario Tellez
Thank you for your answer, I did try this, and it had no display. There is one other light that turns on in the 'tab key'
door Ray
Have the same problem here. Mine is i7 and it won’t turn on sometimes with 65w HA65PM130 Power Adapter connected. But turns on just ok with the battery. I think I need 90w power adapter.
door Colden Haulfield
Swapped the AC to 90w brick (LN90PM130) and all is the same. U_U
