Ga door naar hoofdinhoud
Het model uit 1996 werd geïntroduceerd op de North American International Auto Show van 1995 en is gebouwd op het Chrysler S-platform.
car will not move in reverse.
So i have a 97 dodge caravan 2wd 3.3ltr i was backing out of my driveway and it hesitated befor moving but moved about an hour later i got in and put it in reverse and it would not move. Pressed on the gas a little and it still wouldn't move all other gears work and fluids were checked and are good. I can feel it shift into reverse but no movement and when the gas is pressed it rev's and sounds like it puttered like it was about to backfire. Any ideas?
Is dit een goede vraag?
2 opmerkingen:
Is the an automatic transmission or a stick shift?
door
Automatic transmission
door
Voeg een opmerking toe
1 Antwoord
I would double check those fluids remembering they should be checked warm with the engine running after shifting into all gear options. If this does not work you may have an electrical problem preventing all the necessary solenoids from activating. Your best shot may be to drive it to a repair shop and have them diagnose it. If it is only the solenoid the fix shouldn't cost that much.
Was dit antwoord nuttig?
Voeg je antwoord toe
Sky Simpkins zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 1,918
