Ga door naar hoofdinhoud
The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
door does not open
Drive side 2nd door does not open
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Can you clarify... Does it not open from inside or outside? If only fails to open from inside it could be that it is equipped with child proof lock switches and it has been activated somehow. If that is not the case and only fails to open from outside the lock to door handle pull rod has probably come loose some how. Failure of inside release handle could be a similar issue as well if it is only failing to open from inside release.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Joe Shaw zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 102
