Ga door naar hoofdinhoud
Service manual for 30" A1083 display?
I need access to a service source (Apple) manual for a 30" Cinema HD Display, model A1083, marketing number is: M9179LL/A. Customer wrecked the rounded power connector from the display to the brick. I'd like to find a new connector, not a used one. It's the whole octopus harness coming out of the back of the display.
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
You may have to see if the 27" cable will work. I'm finding nothing searching for the "30" LED Cinema Display All-In-One Cable"
But here is a new 27"
NEW 922-9743 All-in-one Cable for LED Cinema Display 27" A1316
http://www.ebay.com/itm/NEW-922-9743-All...
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks for the tip - but the LED Cinema Display A1316 is a different beast. The 30" one had an aluminum enclosure, whereas the A1316 looks kind of like an iMac. Has 3 USB 2.0 ports on the back. The one I need has 2 USB and 2 FireWire 400's.
door
Voeg je antwoord toe
Robin Ray zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 1,257
