Ga door naar hoofdinhoud
De Sony Xperia Z5 Android-smartphone werd uitgebracht in oktober 2015. De Sony Xperia Z5 beschikt over een 5,2-inch scherm met een resolutie van 1080 x 1920 pixels en is uitgerust met een Qualcomm Snapdragon 810-processor, 3 GB RAM en een 23 MP camera achteraan.
While calling phone screen turns off?
While using any calling feature (phone, facebook, etc) my phone screen goes black and won't turn back on, if the other person doesn't hang up first than I have to manually restart my device to end a call. How do I fix this? Seems to only have started after I installed Nougat 7.1.1.
Is dit een goede vraag?
Score 5
1 Opmerking
can i turn off that sensor that make the screen black when covered ?
door
Voeg een opmerking toe
6 Antwoorden
Het nuttigste antwoord
Do you have a screen protector or a case that may be covering up the proximity sensor? If not, the proximity sensor itself may need cleaning or replacement.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
I had this problem and it was annoying, especially when I had to press the dial pad to go to different services from the number I was calling. So I googled it many times and had all these long winded methods. Then I got a post from a bloke that sounded like he was Russian. When making a phone call and your phone goes blank, just press with you finger in the right hand top corner and the screen comes on again. Thankyou Komrade.
door
Make phone call. When screen goes blank, press right hand top corner of screen.
Screens comes on again.
Score 2
3 opmerkingen:
Thanks for this very helpful information
door
Omg it works thank you!!!
door
2023 still using this trick. Tq very much
door
I have that problem also
Well Ensure that the proximity sensor is not being blocked by foreign objects, a screen protector, or a protective case.
Following might be helpful for you: https://wethegeek.com/how-to-fix-android...
Hi, there is 2 type of problem, first clean your sensor, usually top left of mobile phones, Second may your proximity sensor need to be replace.
i just pressed the top righthand corner and the screen came on !!!** weird or what
Voeg je antwoord toe
Char Duffett zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 19
Altijd: 12,155
