Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
Screen Replacement with old Home Button
If I'm replacing the whole screen, if I just take the home button from the damage screen and put it in the new screen will everything be the same as in Touch ID wise. Will there be any difference?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You are correct, no difference and you'll keep the touch ID :) Just be gentle with the fragile flex cables and keep track of what screws go in each hole and power off phone and disconnect battery.
Update (08/20/2017)
Yes, and the cable that connects the home button and to the logic board that runs along the back of the back plate
Was dit antwoord nuttig?
Score 2
1 Opmerking:
by cables your just meaning the cables that's connecting the display to the main board?
door
Voeg je antwoord toe
aj.haythe1 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 90
