Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Uitgebracht in mei 2012, herkenbaar aan modelnummer J2011-03-US.
Stereo cable entry broken...How to fix it?
The entry to plug the stereo cable on my jambox is brocken. The sound quality is bad if I connect with the cable. With bluetooth, the sound is good. I would like to fix it. How can I do???? Please help!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Sadly Jawbone the company is not well these days: Jawbone is going out of business. Once they were quite innovative with there small speakers and bluetooth headphones.
Sadly, parts are just not available from them. I have seen a few eBay listings of some parts which is where you'll need to look.
Here's the IFIXIT guide to gain access to the assembly: Jawbone Big Jambox Micro USB Port Replacement
If you can desolder the jack socket you might be able to locate an off the shelf replacement at a good electronics parts supply house.
Maybe the better answer here is not to fix it and just use the Bluetooth connection.
Or, look at getting a new speaker. I had two Jawbone units both died, I went out and bought two UE Boom2's which I think are quite good!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
elsdoue zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 346
