Ga door naar hoofdinhoud
Bluetooth on-ear headphones with 40 mm drivers and a 610 mAh battery. Released in 2014.
20 Vragen Bekijk alle
The left side of my headphone is not working!
My headphones not working from some angles. I put on my headphones like others but the left side doesn't work but the if I move it a bit it still works!
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@sherpasonam your question does not tell us what you move to get it working. It does sound like either a bad crossover cable or a bad connector. Of course if you are using the auxiliary cable to connect your headphones, you may have a bad connector on that as well. WE can probably clarify this when you let us know about the part you have to move.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Sonam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,970
