Ga door naar hoofdinhoud
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 Vragen Bekijk alle
How do I fix my DS Lite?
It has a battery problem and it won't turn on, the problem is that I don't really have experience with fixing things. Should I get a new battery for it or what? Or should I get it taken in somewhere local and professional?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi!
Replacing the battery on the Nintendo DS Lite is extremely easy: all you have to do is unscrewing that small philipshead on the bottom of the unit, to the right of the SLOT-2. It's literally the only visible screw there.
No need to send it anywhere.
Getting a new battery shouldn't be that complicated. You should find plenty of them on your local classifields site (such as Craigslist or eBay) , if not, try Aliexpress.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Caitlin Lumsden zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 61
