Ga door naar hoofdinhoud
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
opened dryer while running without hitting pause button
My mom opened the dryer while it was running without hitting the pause/cancel button now dryer wont turn on, the lights are flashing & its keeps beeping. I tried holding down both the start & off buttons but beeping still wont turn off & dryer wont turn on. How do I fix this?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
@hawild unplug the unit from the outlet and let it sit for awhile. Then try again. Keeping it unplugged should reset it. you can also try to hold the "Drain/Spin" button and the "Start (Press & Hold)" button at the same time for no less than 3 seconds
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
We tried that but it didn't work. Thanks
door
Okay so there is no change when you unplug it?
door
My dryer may be different from yours but i held the cancel button down for about 10 seconds. after that, the start button worked normally
Score 1
Voeg je antwoord toe
Heidi Wild zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 1,217
