Ga door naar hoofdinhoud
Laptops manufactured by Dynabook (formerly Toshiba). Toshiba has since transferred 100% ownership of the laptop business to Sharp.
1273 Vragen Bekijk alle
Adobe reader error when opening document
When you click on the button "Open" a pdf document is issued :"there was an error opening this document. Can't find file."
What could be wrong?
Asked the user to check for viruses. He said to periodically check for viruses (Kaspersky).
Is dit een goede vraag?
1 Opmerking
Thank you guys for your feedback and help. Thank you!
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
If you open any other pdf file in the same way error also occurs?
Just try to update Acrobat to the latest version. Or put, for example, Sumatrу. If you do not help this method, then you can restore the file using PDF Repair Kit for adobe pdf repair. http://www.adobepdf.repair/
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Is it just that one file or is it all PDF files.
If its just that file, that file may be damaged or is gone.
If its all, uninstall Adobe Reader and reinstall it again.
If that doesnt fix it let me know and we will find other options
Score 1
2 opmerkingen:
Is it just that one file . and I also think it's damaged
door
If it is, its definitely damaged and there is nothing you really can do.
door
Hi @ernobalog,
First,
1. You can try to move on from older version to latest one.
2. Cross checked once, are you not rename his file along with extension?
if you still stuck, It may be possible that for some special configurations, such as:
1. Mail client you are using?
2. Do you have roaming profile/redirected folders?
3. Do you have any anti virus/secuirty software installed?
You can try, repairing Reader X installation from Help-> Repair option
If you are getting this issue again, recommend to call my toll-free number +1-800-620-8060.
Cheers
John
1 Opmerking:
I'll try to follow your instructions. thank you!)
door
Voeg je antwoord toe
ErnoBalog zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,432
