Ga door naar hoofdinhoud
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
Can I fix this?
I have 2 iPod Touch 5th Generations.
One without the back camera that is currently a miracle. It's casing is bent from being in my front pocket on a roller-coaster and it's screen is cracked from multiple drops and missing bits and pieces. I have no idea how well the battery is working.
The other one has the back camera. The screen is missing a V or check-mark shape piece and the battery doesn't seem to last even 5-10 minutes.
If I can find the second one, which is unlikely since it belongs to my partner who thinks he's thrown it out without factory resetting it...
I would like to know if it is possible to fix the screen and replace the battery.
I know the 5th generation iPod has a repair score of 3/10. I just don't see a clear article on fixing either the screen or on replacing the battery.
If I can't fix it myself, I did have a recent offer of $100 for both screen and battery total. That said, I have to find it first.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
iFixit has several guides on repairing the iPod Touch 5. Here is the one for replacing the screen.
They have low scores due to the use of adhesives and the fact that the battery is soldered in place. So what you want to do is certainly feasible if you have some soldering skills.
Was dit antwoord nuttig?
Score 1
While it is possible to fix this, you will have a difficult time of it, especially if the case is bent. I don't think it would be worth it, as the only way to realistically bend the iPod back into shape is with a tool that costs 40 or 50 bucks. If it's not badly bent and you'd like to try it, I'd say go for it. Here is the best guide (in my opinion) for iPod 5G screen replacement. You can replace the battery while you're at it.
iPod Touch 5th Generation Display Assembly Replacement
Voeg je antwoord toe
Seraria zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 353
