Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Vragen Bekijk alle
What to do with the adhesive around lcd connector
After doing a screen replacement does the adhesive interfere with the repair process. I’ve was in the process in replacing an LCD, I had the battery plugged and that’s when I’ve smoke rise up after I had connected the lcd cable. The smoke had came from the lcd connector and smell burnt. Was the mistake was because of the adhesive or battery not being disconnected while in the process of repairing.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The adhesive has nothing to do with it. The iPhone 6S is very prone to backlight circuit blowouts. You have to disconnect the battery first otherwise you can short the pins of the connector if they aren't lined up properly.
You will have to find a repair shop that does micro-soldering repairs to fix your backlight circuit. This is not a DIY fix.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Sorry, I was typing my question in a hurry. Didn’t realize I had forgotten few words, until now. Thanks, I just notice the pins of the connector wouldn’t snap in easily. I was struggling during the process of plugging it in, that’s when I’ve seen smoke coming out of the connecors. One more thing, if the cables aren’t connected properly, once i plug the battery back in. Can I blow out the circuit in that way?
door
Sure, if the connector is misaligned and you connect the battery, the same thing may occur.
door
Voeg je antwoord toe
Osvaldo Banda zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 7
Altijd: 82
