Ga door naar hoofdinhoud
Sony's Xperia Z5 Compact is an Android smartphone featuring a 4.6" IPS LCD display with 720 x 1208 resolution, quad-core Qualcomm Snapdragon 810 processor, and 2 GB RAM. Released in October 2015.
Notification led blinks 4 (four) times?
I was have problem with my lcd: there was picture but no backlight.
Then;
1-Pulled off battery
2 -Cleaned flex cables with alcohol.
3-Putted everyhing back.
4-Putted battery back.
5-Tryed to power on.
Now:
When i try to power on vibrates 1 time as normal and 5-6 seconds later red led blinks 4 (not three) times. No thing happens. If i try to shut down by sim slot button its acts normaly and vibrates 3 time.
Anyone knows what is the meaning of 4 time led blink.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Sony Online Support emloyees made me crazy. I find my own answer. When lcd or backlight is broken or cant work properly device prevents boot up. 4 time blinks wants to say that! Thanks for Sony's ignorant employees.
Was dit antwoord nuttig?
3 opmerkingen:
i disassbemled my lcd's flex cable and phone booted up normaly (without picture of course.). I will buy new lcd.
door
Did new screen solved the problem ?
door
What is an icd?
door
I replaced the LCD screen and back camera. Now it won't boot up. There is no response at all from any of the reset option. The 120 second reset. The power+volume up, power+volume down. Nothing. When I connect to charger and hold down the power button, the red LED comes on for a second, then turns off, the phone vibrates 3 times followed by the red LED turning on again for a second and then turning off. Then the process repeats. Holding down the power or the 120 second restart button while plugged in yields the same results. I tried repair using pc companion, doesn't work.
Voeg je antwoord toe
mehmed akif ay zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 4,808
