Ga door naar hoofdinhoud
The Zune is Microsoft's portable media player and entertainment platform, originally released in 2006.
57 Vragen Bekijk alle
I would like assistance, please.
I have a zune gen 1 that had gotten slightly wet and a brand new 2nd gen.. Can you remove the a data board to get the info off one and put it in the newer model. Please help! Email: ajade2388@gmail.com
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Ashley Christianson not sure what you are referring to as 1st and 2nd generation Zune, but no you cannot get your file by replacing logic boards. The 30GB and 80GB zune have HDD so there you may have some luck with recovering from the HDD. The Zune HD and Flash 2nd gen store the files on an IC which is part of the circuit board and cannot be swapped.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Ashley Christianson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 47
