Ga door naar hoofdinhoud
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 Vragen Bekijk alle
Vertical lines on lcd after display replacement
I recieved an iPad Pro 12.9" in for repair from another shop. They bought a new display with the daughter already attached, but it is showing a bunch of vertical lines down the right center and nothing else. It doesn't look like they disconnected the battery while replacing the display so im not sure if its just a faulty display or they damaged something on the board. Thanks in advanced!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I have not had to order any 12.9" screens yet but from what I have read on the tech forums, they appear to be quite problematic. I would certainly explore a return or refund with the supplier.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Daniel Grueneberg zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 229
