Ga door naar hoofdinhoud
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
How to fix Hyperflashing LED Turn Signals?
I recently installed LED rear turn signal bulbs onto my 05 Grand Caravan SXT, I want to know a good way to stop the hyperflashing that happens.
Is replacing the fuse with a higher amp my best bet when it comes to this? I don't want to spend too much on this. If this is my best bet what is the fuse/ relay called?
Thank you.
Lights I used
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
No, you need to install a resistor in parallel with the led globe, as the current draw if the Led is not enought to operate the flasher relais properly.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Scott zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 23
Altijd: 654
