Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Model A1419 / EMC 3070 / medio 2017 / 3,4, 3,5 of 3,8 GHz Core i5 of 4,2 GHz Core i7 Kaby Lake-processor (ID iMac18,3) / Retina 5K-display. Raadpleeg de oudere handleidingen van de iMac Intel 27" Retina 5K-display (eind 2014 & 2015), aangezien het systeem sterk overeenkomt.
Is the stand removable?
Is the base/stand/foot removable like in older model iMacs? Is a vesa mount possible without direct order from apple?
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Sorry, you'll want to get the VESA mount model.
So far none of the 'Thin Series' offer a user removable foot. The iMac Pro slideware at WWDC implied it will offer a removable foot. But we'll need to wait to see if it ends up being true.
Update (11/21/2021)
The only way to get a VESA mount 27” iMac is to order it explicitly, you can’t really alter things later.
The complete system needs to be taken apart to replace the foot stand and you need quite a few parts.
Was dit antwoord nuttig?
Score 1
https://www.youtube.com/watch?v=WFSyl9_9...
Score -1
2 opmerkingen:
Sorry guy this was true with the 2011 iMac and the displays. With the 2012 models and newer Apple altered the design preventing the use of the Apple VESA kit.
Only with the intro of the iMac Pro did Apple re-introduce the older design for the foot assembly. So only that model has a removable foot without taking the system fully apart.
door Deel
Yes, but this is a site dedicated to taking these things apart. There are already guides for servicing all kinds of things Apple hasn’t made convenient. If there were anywhere that could put a guide together to remove this inconvenient foot, this is the place.
door Deel
Voeg je antwoord toe
Augustus Cross Mackenzie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 46
Altijd: 10,868
