Ga door naar hoofdinhoud
Een programmeerbaar koffieapparaat van Keurig. Dit koffieapparaat gebruikt K-Cup Pods en K-Carafe Pods om verschillende warme en koude dranken te maken. Modelnummer: K2.0-400 Serienummer: 401.0200.1410931 Dit product is compatibel met stopcontacten die 120 volt ondersteunen en heeft mogelijk een converter nodig bij gebruik buiten de Verenigde Staten.
Piece of rubber hanging down from needle
My Keurig 2.0 is working but there is this little rubber piece that is hanging off from the top. It is a straight piece that then ends in a little rubber circe. The circle is broken.
My daughter is planning on taking it to college with her in September and I was wondering if I can fix this little piece some how.
Update (06/29/2017)
This is a picture from under my machine
Afbeelding
Is dit een goede vraag?
Score 3
2 opmerkingen
Answer is related to the mini-pump, but the question is about the needle seals.
door
this looks like a black rubber washer. Why can't I find them anywhere?
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
This is the seal washer for the needle. I don’t recall why there’s two parts to it. I think mine only has one. It seals between the machine and the top of the pod.
This might work to fix it: https://www.amazon.com/Replacement-Needl...
https://www.bonanza.com/listings/Keurig-...
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
The item from Bonanza should work since my Keurig is a 2.0 K400. The part is a little pricey, but it's cheaper than a new Keurig. I also don't know about the 2nd attached piece, but I guess I will find out! I will order this and keep you posted. Thank you for all your help in locating this part.
door
@willpsree thanks for posting the link excellent find since those O-rings have a tendency of disappearing!
door
This guide shows you the tubing:
Keurig 2.0-400 mini pomp vervangen
Score 1
Voeg je antwoord toe
Phyllis Jozwik zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 47
Altijd: 10,981
