Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Uitgebracht in augustus 2013. Te herkennen aan modelnummer Z796C
Editing my contact information
Hi, I have a ZTE Majesty Pro LTE Z798BL. My service provider is Tracfone/Safelink.
I am attempting to edit my contacts. When I touch the screen, I get a message that says I have disabled required permission. What permission? And how do I re-enable it?
Is dit een goede vraag?
Score 9
4 opmerkingen
I also have this problem and can not find an answer.
door
Yes help me remove message
door
ZTE, never again. I can't delete numbers I don't want anymore. I hate this Chinese built garbage!
door
My phone doesn't allow any contact to save
door
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Het nuttigste antwoord
go into your setting and enable the permissions for your contacts..should be in application settings
Was dit antwoord nuttig?
Score 5
4 opmerkingen:
there are no permissions under settings, I have the same issue, there are no permissions under the apps either for this.
door
I had same problem on new phone and stumbled around for several days. Then happened across this and turned on all permissions in contact applications and the edit now works. Now I have to figure out which permissions I can turn off!
Phil Starr
door
Thank you Phil Starr, I turned on 'all permissions' in contacts an was able to edit my mom's ZTE cell. Thanks again!
door
How do I find the contact applications so I can all he permissions?
door
These Instructions were given me by a Engineering Student (who will be designing Cell Phones) at Walmart in a Cell Phone Kiosk. It was for the ZTE ZFIVE G
Home, Settings, Apps -
NOT apps as I was doing.
Then scroll down to Contacts…
Permissions then…
Storage - Slide the slider thing to the right.
Hope this helps - (I mentioned to her that non of these instructions were “intuitive” - who would think of it and not mentioned in the booklet either - errr! Please when designing cell phones make it intuitive. MHO
How to restore contacts
Update (09/01/2020)
It did not
Resore contacts
1 Opmerking:
On cell majestic. Zte
door
Voeg je antwoord toe
Elena Vaccaro zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 8,201
