Ga door naar hoofdinhoud
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
20 Vragen Bekijk alle
Why is my dash brake light on when driving?
my dashboard brake light stays on while driving the car. I have good brakes because my mechanic checked them.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
christy, it means one or more of the following, the brake fluid is low, the parking brake lever is either up or the circuit for the parking brake switch is shorted, or if the battery light is also on, the car needs a new alternator. Also check your rear brake lights and make sure they are all functioning. Since we are talking brakes here,you should have a mechanic check it out for you. Hope this helps a bit and good luck to you.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
christy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 6,096
