Ga door naar hoofdinhoud
The LG Stylo 2 Plus can also be identified by its model number MS550, which was released in July 2016 . The LG Stylo 2 Plus version has hearing aid capabilities.
What kind of screen replacement do I need?
I dropped my phone and the screen cracked bad. Lots of spider web cracks and glass pieces missing at the bottom of the screen. When I turn my phone on the screen trys to turns on but it is only a navy blue blank screen. I was looking on eBay to find a repair kit but there are screens that run for about $8.00 and then screens and digitizer LCD screens for about $75.00. I didn't realize there were different components and want to make sure whichever one I buy will fix the problem. What parts do I need to purchase?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If you are fairly new to repair i highly recommend purchasing the part with the entire frame, digitizer, and LCD together. This will allow for a much easier repair process. I am not vouching for this supplier or part quality but it would be something like this https://www.ebay.com/i/222481893444?chn=...
If you want to save a little money you can order the Digitizer/LCD assembly without the frame but reinstalling into the frame can be problematic without proper adhesive and placement of the flex cables. The small cost of having it preinstalled in the frame will be a big time saver and help with the longevity of the repair!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Alexis Rodriguez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 693
