Ga door naar hoofdinhoud
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
101 Vragen Bekijk alle
Led Backlight Flip Clip Connector Socket severed from board
hello i have this problem that the little Backlight Flip Clip Connector got got damaged and it got disconected from the board now since it is a really small part i have no idea how to reconectit back to the board,when i try to keep it there with my fingers i see that everything is okay with it pls someone if u have anyidea how to conect this parts
Is dit een goede vraag?
Score -1
1 Opmerking
This is the pic of the conector that has been disconected from the board
http://www.eeshops.com/images/PSP-1000-M...
now this has been disconected this gives power to the backlight of the screeni need any posible ideas on how to glue it back on or whatever way to fix itmy psp works fine bus the screen has no backlight so u cant see a thing,,thats what im trying to say
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
I don't have a clue as to what part you may be referring to. Look under the picture to the right and go to the "Step-by-step Guides" and see if you can either find a fix or tell us what part you're talking about.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
i added the comment if anyone can notice pls post any ideas you may have on the problem
door
thats what im saying now it is broken meaning that is deatached from the board,,i was wondering how to "glue" it back
door
you may need to sodder it back on, if you broke the connector it self then heres the site to buy a new one.....and if you scroll down you will see how it looks like on the mother board....hope this helps............samething happened to me..............http://ziquexwholesale.com/en/sony-plays...
Score 1
does anyone know a tutorial on how to replace the broken back light connector for it?
1 Opmerking:
shiin1000, this is actually quite an old question. I would suggest that you post your own question. Use this link http://www.ifixit.com/Answers/Ask/PSP+10... and give as much detail as possible. It will also help if you post images about your broken part, and the logic board where it belongs. This will be beneficial to get the right answer. Follow this guide Afbeeldingen toevoegen aan een nieuwe vraag to add images to your question.
door
Voeg je antwoord toe
gjergji selenica zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 3,799
