Ga door naar hoofdinhoud
Tweede generatie iPhone. Model A1241 / 8 of 16 GB opslagcapaciteit / zwarte of witte plastic achterkant. Reparatie is eenvoudiger dan bij de eerste iPhone. Vereist schroevendraaiers, wriktools en zuignappen.
Error 6 fix?
I've been trying to reinstall iOS 4.2.1 on my old 3G iPhone, but it throws back error 9 or 6 every time. I've already tried most of the common solutions. Can anybody offer any assistance? Thanks!
Update (06/17/2017)
I also forgot, it's stuck in DFU mode, and the iOS was corrupted when I got it.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Try to flash with 3Utools
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
are you sure all the connections are fine? dock and cable I mean.
door
Yes, and I was doing it wrong anyway. :) I downloaded the actual program, and it fails at 13% saying invalid serial number.
door
This tool is very useful~ And about invaild serial number, you can try to enter your device to DFU mode and flash again.
door
Your device is stuck on DFU, you can exit that with 3uTools.
Afbeelding
Score 1
2 opmerkingen:
With the serial number issue, it refuses to flash. It's also stuck in a somewhat damaged DFU mode, so the only way I can get it to even begin the process is by cheating with iTunes and unplugging it once it reenters recovery mode. I'm honestly a little stumped on this.
door
If serial number issue issue still exists, there may be hardware issue. You are suggested to get a repairman to check your device.
door
Voeg je antwoord toe
Nikola Wozniak zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 641
