Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Een HTC-smartphone, ook bekend als de HTC Pico, uitgebracht in oktober 2011.
How to upgrade with custom ROM...
i want to upgrade the htc explorer with custom rom, pls suggest...
Is dit een goede vraag?
3 opmerkingen
Can you expand on this a bit. One normally does not reprogram the phones ROM.
door Deel
@danj, yes they do if they own Androids. The steps are 1) Unlock the bootloader if its locked, 2) root the phone, 3) Install a custom recovery (i.e.TWRP), and 4) install a custom rom, which is an unbranded updated, security patched, clean Android OS based on AOSP code. The popular one was Cyanogen, but now they have evolved into Lineage OS. In the iPhone /iPad world, one can only JailBreak, but this still leaves the device insecure. Rooting and updating an Android actually can make it more secure. However, forums.xda-developers.com is the proper locale to ask this type of question.
door Deel
@avanteguarde - Yes, I was aware of people doing this. I was trying to pull from the OP what he was looking for. As you noted there are quite a few different reasons and ROM's one could go with.
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi!
Look at xda they have a lot of different roms and usually good guides on how to flash the roms.
https://forum.xda-developers.com/htc-exp...
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
UMASHANKAR zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 1,031
