Ga door naar hoofdinhoud
Het 3520-model maakt deel uit van de 15-serie in de Inspiron-notebooklijn van Dell en werd uitgebracht op 18 oktober 2012. De Dell Inspiron 3520 is een 15-inch laptop die zowel betaalbaar is als in staat is om aan een verscheidenheid aan behoeften te voldoen.
Wifi problems after bios update
Hello.
I have a dell 3520: 6GB ram, 1TB hard drive, intel i5. A few months ago I had to update my bios... The problem became after I did it: At the very moment I started having issues with my wifi like it drops when I close the lid, and whenever I wake up the computer after it would take a looooooong time to wifi to start working, and actually, drivers disc won't detect the wifi card anymore. Moreover, the bluetooth doesn't work anymore. It doesn't shows up at all as installed in the devide manager.
I've been wondering if updating bios had something to do with it... So, I had thought to downgrade it to the previous version but then I came to find out that it is almost impossible (because I tried it and it was). So, any solutions to these?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
What i would do
Download the drivers from the manufacturers website using another device. Transfer using USB. Try to install and see what happens.
option2:
Find a cheap external wifi adapter and use that
option3:
Reinstall windows and see if it autodetects drivers
Hope one of these helps
Was dit antwoord nuttig?
3 opmerkingen:
I've done that and it all stays the same!
door
even an external adapter?
door
Not with an external adapter. I tried installing the original so which was W8, then tried W7, and neither recognized wifi and bluetooth adapters. Actually, in order to make wifi work I had to search the driver in a weird czech page... Actually, bluetooth has never worked again since I made the bios update.
door
Voeg je antwoord toe
jrgg1994 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 837
