Ga door naar hoofdinhoud
American Edition released in 2013, identified by model number X502CA
Why is my keyboard pressing 2-3 keys while I press 1
Hey there
So I had some water spilled on my sister's asus laptop.
After telling her to quickly turn it off I opened it up and aired it for about a day,after reassembling it everything was working properly beside the keyboard.
Some keys or even most of them are working just fine but other like 7 are pressing(not physically)on 'y' and 'u' as well.
Could there be a solution or I just need another keyboard top if it's even possible to disassemble just the keyboard
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Have you tried an external Keyboard? I would do this to isolate the issue. If the external keyboard works fine, its almost certainly going to need a replacement keyboard.
ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement
Cant imagine any software causing the issue
Best of luck
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Yeah external works just fine
And I can take it apart to the step where I have the whole arm rest with the keyboard and all.
Is it possible to remove the keyboard from it?
door
http://www.laptopkeyboard.com/Guides.php... this is the only video i could find. Hope it helps
door
The keyboard has shorted out. Replace it.
Here's the part:
https://www.any-pc-part.com/product_info...
Here's how to do it:
https://www.youtube.com/watch?v=Vo5GlyQT...
Score 2
Voeg je antwoord toe
Netanel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 140
