Ga door naar hoofdinhoud
De RCA Voyager II is een 7-inch tablet geproduceerd door RCA.
battery won't keep a charge
I have purchased two RCA tablets for my sons on Christmas 2016 and one battery won't charge at all and the other one the battery runs down too quickly) the charge won't hold. I have tried emailing you support service for tablets but the email address I have isn't valid support.rcatablets which is in the paper that comes with the tablet.
Please help me with this. I need a way to contact someone about these tablets.
Is dit een goede vraag?
Score 2
3 opmerkingen
Could you please provide a screenshot of the battery usage section under settings?
door
mine has this to it started when i was using a charger my tablet said this charger was notcompatible so i unplugged it and shut it off i tried to turn it back on and now i have had this dead voyager for 1 year now
door
I have had trouble with every single one I have bought……I really feel ashamed of RCA for making such a product….that so many have the same issues…..RCA used to be a reliable and dependable company with great products ….that consumers were happy to have….because their products were reliable and dependable …..with very long life…..now these tablets are running the company name into the ground…..I am very unpleased with this product and seeing so many with the same issue…..leads me to believe they are not manufacturing them correctly
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
@tryingtoohard, Pamela, If under warranty this may be info. needed. From RCA site (1st link) below. RCA North America, Android & Windows Tablets Phone: 877-252-6873 / 800-252-6123.
If you know the chargers are working correctly and the charge ports look clean inside(no dust/lint/debri) and charge ports look good no damaged pins/loose, the issue may be quite simply faulty batteries. In case you would like to try repair your self or another family member/friend, I have posted a disassembly guide(2nd link) and possible replacement battery(link#3) which you can do a search on for possibly better pricing(ensure replacement battery is correct for your model#). A good local computer repair shop may also be a viable solution if not wanting to attempt repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.rca.com/support-products
RCA Voyager II RCT6773W22 uit elkaar halen
http://www.ebay.com/itm/RCA-7-034-Genuin...
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Great disassembly guide - I have found sometimes that these things just lose their mind and may get "stuck" at say 14%, but if you measure the battery, and it's at 3.8 or more volts, just disconnect the battery, wait a minute, and re-connect it and see if the battery power is now correct (say 60% or more) then charge it.
door
Why wont it keep a charge any more than 45
Voeg je antwoord toe
Pamela zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 11,354
