I'd start by following Deep dive suggestions from Apple but would stop at #7
Deep Dive
1. Verify boot chime present and fans running when computer powered ON. (Reset SMC and clear PRAM if necessary for proper boot up.)
Yes Power on self test OK.
Go to step 2.
No Go to Won’t Start Up symptom flow.
2. Verify if image is visible on built-in LCD panel, with adjustable backlight level.
Yes Video present. Verify system functionality and return to user or go to appropriate troubleshooting flow.
No Go to step 3.
3. Connect supported external display. Verify if image appears on external display when system is booted.
Yes External display detected by system. Video circuitry on logic board functional.
Go to step 4.
No Go to No Video symptom flow.
4. Verify if LCD backlight is ON by looking for faint glow from display when viewed in darkened room with brightness set at maximum.
Yes LED backlight is functioning.
Go to step 7.
No Go to step 5.
5. Shine bright (low heat) flashlight onto front of LCD. With computer powered ON verify if a faint image is visible.
Yes LCD panel functional but backlight is missing or dim. Remove LCD panel and inspect and reseat the
following cable connections:
-Backlight power cable
between backlight board and LCD panel.
-Vertical sync cable between backlight board and LCD panel.
-DC power cable to backlight board and power supply.
Replace any damaged cable.
Reinstall LCD panel and go to step 6.
No No image or backlight.
Go to step 7.
6. Power ON system. Verify if image is now visible on LCD panel with correct backlight level.
Yes Issue resolved.
No Replace LED backlight board.
Retest. If issue persists, go to step 7.
7. Inspect and reseat internal DisplayPort cable (between logic board and LCD panel).
Power ON system. Verify if image is visible on built-in LCD display.
Yes Issue resolved.
No Replace internal DisplayPort cable.
If issue persists, replace LCD panel. Run Apple Service Display Utility to verify the resolution of intermittent display flickering symptoms. If the Apple Service Display Utility fails, contact Technical Service Provider Support
Anything after that, you'd have to measure some voltages on your logicboard.
Do you have a spare working screen around to test? Usually is the screen on this model.
door Cosmin
@angelorecaman You appear to be repairing Apple products professionally. Would you mind expanding your profile so we can get to know you better?
door mayer
@mayer
What kind of info do you need? On the menu MY PROFILE nothing that I need to update!
door Angelo Recaman
You are correct Angelo, after looking over your questions I know all I want about you. @oldturkey03 may be more able to help you than I. Mike what do think of our Sanguisugæ OP?
door mayer
Hi,
did you get solution or not yet,I have Exactly the same issue imac 27" 2011
door Hany Hanna
8 commentaren meer tonen
