Ga door naar hoofdinhoud
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
553 Vragen Bekijk alle
Riding mower emits blue smoke
Sears riding mower emits blue/white smoke starting two days ago. Added Lucas oil leak additive after using Lucas engine clean and still smokes. I had Sears tune up last summer with new oil, air, fuel filter and oil change. Is this worth trying to repair?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
@chuckypoo, Charles, If your sears mower was equipped with the Briggs and Stratton eng., may have a failed head gasket as it seem's to be a often occurrence. If mower is still in good condition it would be well worth having diagnosed, especially if it was only needing head gasket or even simpler repair.
Blue or white smoke coming from your engine usually indicates burning oil, which can be caused by:
-Overfilling the crankcase with oil
-Incorrect oil grades
-Operating engine at greater than a 15 degree angle
-Inoperative crankcase breather
-Crankcase air leak
-Blown head gasket
-Worn cylinder and/or rings
Links below may help trouble shooting and repair of head gasket. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.briggsandstratton.com/na/en_...
https://www.youtube.com/watch?v=aO_m-2z-...
https://www.youtube.com/watch?v=NM28FSoU...
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
-Crankcase air leak
-Blown head gasket
Score 2
Well this post is about cars, but I'm pretty sure it applies: https://www.emissions.org/types-exhaust-...
Voeg je antwoord toe
Charles Willis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 71
Altijd: 11,609
