Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Touch ID Flex Cable Tore
Hello I was fixing the screen on my iPhone and being a bit too excited i tore the touch id flex cable not the one on the home button but the one that connects the button to the motherboard on a metal plate If i replace this will touch id still work
Cheers
Ben Cybulski :D
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Yeah, absolutely. If for some reason Touch ID doesn't come back, then the cable is the issue. I.e. Bad cable. If everything with the home button is just fine
iPhone 6 Home Button Link Cable
iPhone 6 Home Button Link Cable Afbeelding
Product
Was dit antwoord nuttig?
Score 7
4 opmerkingen:
Thank you so If i use the cable touch id will come back and the home button will work?
door
Yeah, if it's just that cable, then you're good to go
door
that cable is just an extension from the home button to the motherboard. if the home button is good touch ID and function will be working good.
door
It doesn't come back because the flex cable is linked to the main board and so switching thecable will block the use of touch id
door
Voeg je antwoord toe
Ben Cybulski zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 834
