Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
iPhone 6 stucked in apple logo after replacing u2 ic
Hi. A customer brought to our store an iphone 6 dead after plugging in car charger. I replaaced the u2 ic and it started charging with the correct voltages but it just stucked at logo and wont go further. I see no short and the mainboard doesnt heat. It didnt fall to water. The voltage going into battery is between 3-4.xx help pls. The client doesnt want to lose his inforrmation.
Actualización (25/05/17)
I did it maany times now. Same result. The voltage is ok tho in the baterry conector from the board. If the u2 is placed incorrectlly it will just dont charge or the voltage in that conector should be less that 1v
Is dit een goede vraag?
1 Opmerking
My friend the probllem is that the cliennt wants his information back. All he wants from the. Iphone is the information
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
I would first repeat the chip replacement since this can occur after a bad Tristar chip replacement.
Was dit antwoord nuttig?
Score 6
3 opmerkingen:
There are many other things that can be wrong. One of them simply being the data is corrupted and you need to update or restore (and loose data). Can you connect to ITunes?
door
That's good to know. @rany I got a 5S boot looping and flashing red screen. Definitely water damaged. But I'll be glad to try the u2ic before anything else
door
You'll need to disconnect front cam, fit a known good battery, make sure gas gauge is attached, replace Tristar, and restore from DFU.
door
hi friends i have iphone 6 full short after change u2 ic please tell me solution
1 Opmerking:
check which path is shorted. vcc bat or main
door
If you have between 3v and 4v and only apple logo, the U2 chip is not soldered well. It helps just to reheat it better to solder all balls. BR
Voeg je antwoord toe
Jackychang zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 2,597
