Ga door naar hoofdinhoud
Repair guides and support for tablets manufactured by ProScan.
57 Vragen Bekijk alle
will a crack in the scren stop the touch screen option
I stepped on my Proscan PLT8802G and cracked the screen. There are 2 cracks and they start in the same place , right above the jack where you plug the key board in. 1 crack goes to one side and the other one goes to the other side. I can turn it on and it charges but that is all. The key board does not work and the touch screen option does not work. When I touch the screen I can see the screen gets darker where I'm touching it but nothing gets activated. What can I do to fix this Please and Thank you very much
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sounds like you broke the digitizer . This guide will help you through the repair process
ProScan PLT7223G Screen Replacement
You can find screens on ebay and amazon you need to be more specific with the model if Im to direct you to them . Hope this helps
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Dorothy Davis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 313
