Ga door naar hoofdinhoud
ProScan PLT7223G Screen Replacement
Wat je nodig hebt
    1. ProScan PLT7223G Screen Replacement, Screen: stap 1, afbeelding 1 van 1
      • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
      Vraag FixBot
      Voeg opmerking toe
    2. ProScan PLT7223G Screen Replacement: stap 2, afbeelding 1 van 1
      • Use the blue plastic opening tool to pry open the tablet.
      • You will hear popping sounds. That's okay.
      • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. ProScan PLT7223G Screen Replacement: stap 3, afbeelding 1 van 1
      • Remove three 4 mm screws from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. ProScan PLT7223G Screen Replacement: stap 4, afbeelding 1 van 1
      • Insert a spudger under the black tape that connects the silver wire to the interior of the front panel
      • Pull back the black tape with the spudger until it can be lifted up with your fingers.
      • Use your fingers to grab and lift the remainder of the black tape from device panel.
      Vraag FixBot
      Voeg opmerking toe
    5. ProScan PLT7223G Screen Replacement: stap 5, afbeelding 1 van 1
      • Use a plastic opening tool to push back the ZIF connector to release the ribbon wire on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    6. ProScan PLT7223G Screen Replacement: stap 6, afbeelding 1 van 1
      • Insert an opening tool underneath the silver base of the internal device element.
      • Use the opening tool to pry the element out of the case that holds the screen.
      • You will need to release a number of clips in order to remove the screen.
      • Be careful not to damage the motherboard or battery as you go.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 27
Altijd: 2,109
