Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
20 Vragen Bekijk alle
iPhone 2G stays on a thin red battery icon
Hi to all my Iphone 2G stays on a thin red battery icon, blinks 3 times and goes black. By repushing sleep same process. The apple logo never comes up. DFU modus not possible. I opend the phone and meassured the battery which is 3.55V, so the battery should be fine. iphone is since 24hours charging on the wall socket. Can somebody help.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If the red part of the battery image flashes three times and then the screen goes blank, it means the iPhone is not receiving power to charge. Have you measured the output of your wall charger? It might be that your wall charger is not working. also your need to take a look at the cable is it working. did you clean the connector on the phone? Make sure it is clean and free of debris. If all of those are working I would go ahead and replace the battery in the iPhone. It might have the voltage but not the amperage to power your phone. These are just my 2 cents but I hope this helps a little. Good Luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Schibi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,447
