Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Vragen Bekijk alle
After replacing iPhone 3GS Dock Connector: Antenna Signal is Weak
I just replace the Dock Connector on my iPhone 3GS. Everything seems to be working fine but I'm getting weak GSM Edge and 3G signal.
I read iPhone 3GS Replaced dock assembly wifi good but very weak GSM Edge 3G, and verified that all the screw are in place correctly and the white bit that came with the antenna is were the do not remove sticker was. However, I'm still getting weak signal.
There's a copper tab on the antenna, is that supposed to come in contact with the case bezel (ie does it use the case bezel as an extension of the antenna)?
Also, doe's anyone have any other ideas on what may be causing this problem?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
14 Antwoorden
Gekozen oplossing
I think you 've answered this yourself! yes the small tab on the flex connection forms part of the antenna with the bezel, simply put the tab in contact with the bezel and you should notice the change immediately.
Was dit antwoord nuttig?
Score 2
I found out that my eBay replacement part gave me crap reception. So my fix was use the apple arieal and eBay dock connector. Simply job rip off the sticker on the back of the dock connector and replace with your old one. Works gave me back full signal :) The little tab has nothing to do with signal as I use my apple aerial with the iPhone apart and made a call lol
Score 2
I feel compelled to add that what Sparky says is true.
I was also having bad reception issues after i switched out my dock connector.
luckily i saved the original one. i peeled off the anttena from the old one, stuck it on the new connector, installed it and it works like new now.
THNAKS FOR THE INFO SPARKY, U THE MAN!!!
Thanks Guys had the same problem my battery ran out and would no longer charge so i ordered a dock connector and battery and wow putting my old dock connector back in sorted this issue out immediately.
Sparky whoever you are, YOU ARE THE MAN!!!!
I have crap reception, I read that replacing the docking connector will solve this, is this true?
Exactly the same problem....did exactly the same as SPARKYTHEBRAVE suggested and bingo works perfectly, full signal. Thanks sparky, saved my sanity!
I also replaced my docking connector from one off of ebay. Now my reception is very bad. Though I already threw out my original one.
Any suggestions as to where to get a good replacement antenna to stick onto my ebay docking connector?
glad I found this, just used my original apple antenna and it all works fine
The iPhone 3GS has a coaxial antenna connector about 1.5 cm (1/2") above the microphone. Make sure it is properly connected.
can anyone post a picture of what the antenna looks like? all help appreciated thanks
Bloody brilliant - worked like a charm Sparky!
Pictures of the antenna flexible circuit I changed back to the original Apple on after changing the docking connector (that came with a ^!^*-poor antenna)
Afbeeldingsinhoud bekijken:
Just came across this website looking for answers as to why my reception was extremely poor to none after doing dock assembly replacement and battery change. I performed the sparky maneuver and voila 5 bars. I can only say thank you and God bless you for sharing your knowledge. I don't have to buy a new phone now.
Voeg je antwoord toe
pjscott zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 16,671
