Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Logitech Performance MX Mouse is een eersteklas muis van Logitech met darkfield-trackingtechnologie en een vrij draaiend scrollwiel. Uitgebracht in 2009. Modelnummer: 910-001105.
Mouse wheel rubber replacement
The rubber on the scroll wheel is somewhat loosen up on my Logitech Performance MX. This renders the wheel to operate without the frictionless scrolling. How to tighten or replace this rubber
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Het nuttigste antwoord
Exceedingly common problem that happens very quickly with this mouse. The rubber loosens, and the slack gets caught in the gearing.
Just cutting it off seems to be the only solution, though with some trial and error you might find a rubber o-ring that fits it.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Just cut it off, why didn't I think of that? Took it apart and everything, couldn't think to just cut it off. Works perfect now. Thanks bro!
door Deel
I use silicone rings the kind for women's jewelry, for replacing the rubber. They're for people with metal allergies. Just figure out what size your wheel equates to in ring sizes and get a size down so the ring fits snug around the wheel and won't slip around. I stick to thinner women's sizes cause the regular ones are usually too thick. I ordered a bunch of different thickness/widths from amazon to see which ones worked for my mouse then returned whatever didn't fit.
door Deel
I will apply this idea to fix my Logitech VX Nano.
https://youtu.be/uHgs8B_6c7I
Watch this video: https://www.youtube.com/watch?v=hxhF5F5F...
Voeg je antwoord toe
Mohd Razwan Rusli zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 53
Altijd: 8,835
