Ga door naar hoofdinhoud
De Nintendo DSi is de derde versie in de Nintendo DS-reeks en maakte eind 2008 zijn debuut in Japan.
Top screen faded with flickering lines
One day, I turned on my DSi and the top screen was faded with what looks like interlacing artifacts always going down the screen. Today, I took it apart, cleaned all of the contacts with 70% isopropyl alcohol and I noticed that the screen works completely fine without the shoulder buttons and SD Card slot (back panel) connected. However, when I plug the back panel back in, the problem appears again. I don't have a lot of knowledge when it comes to electronics so I decided to come here to ask how to fix it. Thanks!
Is dit een goede vraag?
Score 6
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hello,
I had the same problem today and discovered, that there are some kind of potentiometers, wich are regulating the screens in some kind. However, you find them if you look on top of the battery. There are two little screws that you can turn to calibrate the screen. The left one is for the lower screen, the right one for the upper screen.
Afbeelding
Sorry for my bad english but I hope that this could help you.
Was dit antwoord nuttig?
Score 11
7 opmerkingen:
Well, I noticed you posted this back in 2017 so this is pretty much useless.
door
No that worked! Thank you so much I thought it was broken for sure!
door
You´re welkome :)
door
Is this the same for the DSi XL? I opened the batery cover and see two gold screws but no phillips head groove on them. What do i use to adjust them? Thanks.
door
Does this work with the DS Lite model?
door
2 commentaren meer tonen
I thought those were screws and broke the right one by accident .. is there anything I can do about it?
1 Opmerking:
Not sure if this is still relevant. but i broke one of them as well. the way i managed to fix it was by replacing the cable those potentiometers are on. i was able to find one by searching for a DSi SD card slot ribbon cable. i was able to get one for about 10$ for reference
door
Voeg je antwoord toe
Rylan Corral zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 105
Altijd: 13,414
