Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Screen Not turning on
I repaired an iPhone 6s screen, the display no longer turns on at all, but the phone still vibrates and is recognized by iTunes. The home button still works because I am able to turn it off without actually using slide to unlock, I can force restart/shutdown it.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You probably blew the backlight circuit on the logic board when you replaced the screen. The iPhone 6S is very prone to this.
Did you disconnect the battery prior to removing the display connectors?
Shine a bright flashlight on the screen; if you can see a dim image, then you have a backlight issue. This requires a micro-soldering repair and is not DIY.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Robert Hayek zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 147
