Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Deze laptop werd uitgebracht in september 2010 en is herkenbaar aan het modelnummer Inspiron N5030 of Inspiron 15. Het is een volledig zwarte laptop met een DELL-logo in het midden van de bovenste bedekking, een touchpad met gescheiden linker- en rechterknoppen, en een schijfstation aan de rechterkant van de computer.
compatability of ram and cpu
I have a dell inspiron 15 N5030 with a Pentium T4500 dual core cpu and just bought 2x 4GB DDR3 1333 (CP3-10600) SODIMM chips for upgrading....I want to upgrade the cpu to the Pentium T9500 core duo cpu and want to know if it will support the same ram chips I bought? thank you very much for your time.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Het nuttigste antwoord
Stephen -
According to Dell support site (http://downloads.dell.com/Manuals/all-pr...) Page 75, the N5030 will support up to 4GB of DDR3-1333, so you should be Ok.
Russ
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
He has 8 Gb of ram that he got. So he wont be ok.
door Deel
Ooops! Thanks.
door Deel
A lot of time, they only test out to 4GB but, I have put in twice that amount and had it work with no problem. It will probably be fine.
door Deel
Russ above said that it supports 4gb but i find that its very possible that it can support 8gb.
Give it a shot. As long as you have a 64 bit version of windows, you should see all 8gb. It wont hurt anything if you do not.
Hope this helps! If it did please hit the accept answer button!
Score 1
thank you everybody for your input....yes I have a current 64 bit windows system....I am currently waiting for that 8GB worth of DDR3 1333 CP3-10600 chips cause I found out the stock t4500 is a 1333 system...am I right in assuming the stronger 9500 would support the same amount? and is it a 1333 cpu also? or more...I can't find the specs anywhere
3 opmerkingen:
Instead of upgrading the CPU, you would get a better speed kick if you upgraded the hard drive to an SSD.
door Deel
I know ssd drive is way faster than my current hard drive in my dell inspiron 15 N5030 that is running at speed of 5400rpm...I want to know if installing an hdd drive at 7200 will increase my speed more than upgrading the stock t4500 cpu to t9500 at an increase of 2.3ghz to 2.6?
one other factor you should know is that I have the ram maxed at 8gb dual channel and is running at a speed of 6-6-6-15 clocks/latency which I've been told is faster than the chips were designed for
door Deel
Hello Stephen,
Have you got success with upgrading CPU and RAM memory?
door Deel
Voeg je antwoord toe
Stephen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 21
Altijd: 2,431
