Ga door naar hoofdinhoud
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Vragen Bekijk alle
Why is my iPod touch freaking out?
My ipod touch is making a ''little box" around every app I touch and i have to double-tap for the app to start. It also won't let me scroll down on anything(ex. settings, safari pages, etc.)Another thing it has done is rarely let me get to my second page of apps. My ipod also shouts out everything I do so if I'm entering my passcode it shouts out the numbers of it, and a more annoying one is when my screen is locked...
In wrap up it has...
  1. 1: A little box around each thing I touch...
  2. 2: I have to double tap to get to the thing I want to get...
  3. 3: No scrolling down...
  4. 4: Rare access to my second page of apps...
  5. 5: Shouts out everything I type...
Is dit een goede vraag?
Score 18
11 opmerkingen
Rachel, did you try to restore it under iTunes?
door
it does all that stuff to mine!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
door
@kennedy, and what have you done about it? Have you tried the solution that I proposed in my original answer?
door
it does it to me 2
door
guys same case and im crying please help....how do i even scroll down in the settings to click accessibility?
door
6 commentaren meer tonen
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
Rachel is it possible that you have the accessibility options on. It does sound like it, at least most of your problems. Check out this link and see if that is familiar.http://www.apple.com/accessibility/itune... and here is how to manage it. http://support.apple.com/kb/ht3577 but these are just my 2cents and I may be way off:) good luck
Was dit antwoord nuttig?
Score 15
18 opmerkingen:
I love you. oldturkey03, I was literally about to cry because I didn't know how to fix it. Until the part telling me how to scroll so I could get to accessibility. So THANK YOU. :)
door
it worked thanks alot..big help..
door
U r welcome :-) good luck.
door
OMG thank you sooo much! such a relif i thought i would have to take my ipod back O.O
door
same!!!! its really anoyinng
door
13 commentaren meer tonen
triple tap the home button or go to settings >general>accessibility and TURN OFF voice over
Score 4
4 opmerkingen:
That is what the links in the original answers are saying.....:-)
door
How do you fix it
door
How do you fix it now m hole screen turned black
door
See Bryan's easy answer. This works, was easy to understand and is quick. I followed the apple support link into confusion and dismay, yet Bryan's took 10 seconds and a few double clicks. Cheers mate!
door
Rachel this is the voiceover in accessibility, you might have turned it on. I suggest you go to settings, then general, then accessibility, from there you would see the voice over, tap it. Then turn it off.
By the way, for you to do this, you need to scroll down which you cannot, so use three fingers simultaneously to scroll. I hope this solves your problem :)
Score 3
3 opmerkingen:
Thank you so so so much!! I was going crazy trying to figure this out today! Your post saved me some grey hair!
door
i had the same thing happen to me and the 3 finger thing actually works so thanks
door
Brilliant thanks for the info. My daughter had the same thing. I thought we were going to have to replace it. It took a couple of tries to get the three finger scroll thing to work but it did. Working perfectly now. Thank you.
door
Go to settings, and click on genaral-accesibility-Turn off the voice over!
Score 2
1 Opmerking:
how do i click accessibility if I cant scroll down? How do I scroll down?
door
Sync It To iTunes && Click Configure Universal Access..
Then Where It Says Speak Auto Text Click That Box Until It DOES NOT Have A Box Anymore. Then Click Apply. If Apply Isn't Optional Then I Guess Press Sync.
Hope I Helped.
I Had The Same Problem.
Score 1
go to settings if not able to slide over to it use three fingers to swipe go to general three fingers scroll down to accessibility and turn voice over off by double tapping
Voeg je antwoord toe
Rachel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 59,565
