Lamp replaced still no picture
I replaced lamp with new one. Still no picture. The lamp just flickers and makes crackling sound
Is dit een goede vraag?
Score
0
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 126
@ged52 did you check the ballast as I suggested on here No picture even though lamp replaced
door oldturkey03
Not yet. I need to get a meter.....the one I have has a bad wire. When I check it can I insert the probes into to lamp connection points or should I check it some other place for the voltage. I believe the proper voltage reading should be 280 V. Is that correct. Thank you for your advice.
door Greg
I put a meter on the connectors for lamps and it blew my meter. I had it set on 700V. Not good
door Greg
@ged52 the voltage between the power board and the ballast is 220 to 440V but on igniting the ballast can exceed 1000V
door oldturkey03
I checked the voltage to the ballast assembly coming into the board and it is Ok.
door Greg
1 commentaar meer tonen
