Ga door naar hoofdinhoud
Repair guides and support for tablets manufactured by LG.
it will charge then stop?
it will charge then wont its a lg vk410
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Alexis Smith, The battery, cable/charger or charge port may be faulty damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections and reconnect/install battery, still not charging battery probably faulty. If port is found to be bad/loose/damaged, a new charging jack flex cable with bracket can be purchased and installed. I will post a link to a disassembly video/guide to get you inside the tablet to check the charge port. The last link is to new new charging jack flex cable with bracket, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
https://www.youtube.com/watch?v=sRR8OAvi...
http://www.ebay.ca/itm/LG-V400-Tablet-Ch...
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Alexis, can you clarify "then stop"? Do you mean it always charges to a specific percentage and then stop, or does it mean you are no longer able to charge at all now?
door
it will say charging then a few miniutes later it will stop[
door
Voeg je antwoord toe
Alexis Smith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 103
