Ga door naar hoofdinhoud
Repair information for the Fitbit Charge HR. Released in January of 2015. Model numbers: FB405BKS (small) and FB405BKL (large).
20 Vragen Bekijk alle
My Fitbit doesn't charge and I don't know why
Hi , I haven't been using my Fitbit for a while, last week I wanted wear it but obviously it was run out of charge. When I plugged it in nothing had happened and it doesn't get charged somehow and I don't know why and how to make it work. What can I do??
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Noorjan, If under warranty return for repair/replacement/refund. If able to try a different compatible charging source cable/charger to rule out faulty charger. You may want to try changing the battery as it may be faulty. Battery replacement guide link below and link for battery which you can do a search for also for better pricing perhaps. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Fitbit Charge HR Battery Replacement
http://www.ebay.ca/itm/Brand-NEW-LSSP-LI...
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Noorjan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 188
