Ga door naar hoofdinhoud
De Venue 8 is een Android-tablet uit het middensegment, uitgebracht door Dell in 2013.
Part of the screen is black
I dropped my dell venue 8 tab and a part of the screen has gone black.The screen is intact but that one part of the screen remains black no matter what I do.Can someone help me with this?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
arzoo arzue, Sounds like a damage LCD. Below is a guide(2nd link) to enable you to get inside device to check and reseat connections in case this is the issue. If screen still not working properly the LCD screen is probably damaged and needs replaced. 1st link is a replacement display if needed, which you can also do a search on for better pricing perhaps. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.parts-people.com/index.php?a...
Dell Venue 8 scherm vervangen
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thank you so much for your help.:)
door
arzoo arzue , Your welcome thanks for replying back and feel free to select answer as your solution. Good luck with your Venue.
door
Voeg je antwoord toe
arzoo arzue zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 350
