Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
I need to replace just the button only
My button is cracked only, but works, I replaced the screen, came with a new home button now I need to replace just the button only there is some solder pads there, can you unsolder just the button from the module and solder it to the original home button assembly?
Please advise urgently.
Mushtaq
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Just replace keytone, not solder.with multitester, check line homebutton in flex cable
Was dit antwoord nuttig?
2 opmerkingen:
How do I remove the button only, I don't understand please advise.
Mushtaq
door
I need to use the home button assembly from the original screen for ID touch but the button itself is cracked is it possible to remove and fit a new button that came with the new screen, thanks, Mushtaq
door
Voeg je antwoord toe
Mushtaq Mahomed zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 49
