Ga door naar hoofdinhoud
The FinePix XP50 is built to deal with the wear and tear of the elements. Repair of this device can be difficult and requires phillips head and hex screwdrivers, as well as prying tools.
The battery cover is not opening
The battery and sd card cover will not open. It is stuck closed. Can you please advise?
thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@geefamily , GeeFamily, The link below shows how to open battery door. If quite stuck, use a heat gun/hairdryer to heat up around the battery compartment door latch area(carefully heat, not excessive) and then try opening may have to pry a little while sliding/pushing the buttons to open position. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Fujifilm FinePix XP50 Battery Replacement
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
GeeFamily zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 31
Altijd: 2,569
